Click for Nordhavn Click for Abeking Click for YF Listing Service Click for Abeking Click for Ocean Alexander
1600 SHP Turbines for sale
Discussion in 'Buy/Sell/Trade' started by CALA727, Feb 27, 2011.
  1. CALA727
    CALA727 New Member
    paris
    Hello,
    I have for sale severals Engines Turbomeca Turmo III E6, those engines were overhauled by the manufacturer and are since stored inside a container, they are available with all the accessories + associated documentation.
    Please advise if any interest.
    JC Calabuig
      115.7 KB
  2. K1W1
    How much are you looking for for these units?
    You should not post things for sale here without including this info. Not sure how much interest there will be on this site for those but as I have good contacts in the aviation business if they are what you say they are there should be some interest.
    Ca you PM me the Serial Numbers?
  3. weto
    weto Senior Member
    NOR CAL
    What the hay ? What are those generally mounted on K1W1 ?
  4. lynnc
    lynnc New Member
    Dallas,Texas
    :D:D Go fast boat?
  5. Kevin
    Old French helicopters.
  6. discokachina
    discokachina Senior Member
    And very few Breguet French aircraft in the late '50s early '60s.
  7. weto
    weto Senior Member
    NOR CAL
    It appears they also have a marine version as well ?
    GE Marine
    The LM1600 marine gas turbine is a simple-cycle, two-shaft, high-
    performance engine. Derived from GE’s F404 aircraft engine, the
    LM1600 is comprised of a gas generator, a power turbine, attached
    fuel and lube oil pumps, a fuel control and speed governing system,
    associated inlet and exhaust sections, lube and scavenge systems
    and control—as well as devices for starting and monitoring the
    engine operation.
    The LM1600 has four major components: a 10-stage, 22:1 pressure ratio
    compressor with two stages of variable stator vanes; a fully annular
    combustor with externally mounted fuel nozzles; a two-stage, air-cooled
    turbine; and a two-stage aerodynamically coupled low-pressure
    power turbine which is driven by the gas generator’s high energy
    exhaust gas flow.
    The LM1600 marine gas turbine is frequently housed in a highly shock-
    resistant, thermal acoustic enclosure and mounting base. The enclosure
    attenuates noise in the engine room and provides sensors for inlet-icing
    and fire detection. It also houses fire extinguishing equipment. Various
    GE Marine System Suppliers of the LM1600 have designed modules for
    housing the engines they package.
    These modules are usually pre-wired and factory-tested for easy
    installation. The weight and dimensions of these modules vary
    depending on the packager’s design. The typical weight is 24,000 Ibs
    (10,909 kg), and typical dimensions are 22.3 ft long x 7.9 ft wide x 9.3 ft
    high (6.8 m long x 2.4 m wide x 2.8 m high). The inlet duct flow area is
    20.5 square feet (1.9 sq m) and the exhaust duct flow area is 31.0
    square feet (2.88 sq m).
    The simple modular design of the LM1600 incorporates many features to
    maximize shipboard maintainability and parts replacement downtime,
    such as a split compressor casing, in-place blade and vane replacement,
    in-place hot section maintenance and accessible external fuel nozzles.
    Performance
    Output 20,000 shp (14,920 kW)
    SFC (lb/shp-hr) .376
    Heat rate 6,928 Btu/shp-hr
    9,290 Btu/kW-hr
    9,801 kJ/kW-hr
    Exhaust gas flow 104 lb/sec (47.3 kg/sec)
    Exhaust gas temperature 950ºF (510ºC)
    Power turbine speed 7,000 rpm
    Average performance, 60 Hz, 59ºF, sea level, 60% relative humidity, no inlet/exhaust losses
    LM1600 Marine Gas Turbine
  8. Marmot
    ... in a universe of turbines where the Turmo might serve as the starter motor.
  9. K1W1
    I am curious as to what a pst about the very well known LM 2500 Group of GT's has to do with a pair of old Lynx GT's for sale by another member.
    There is a yacht with a couple of the top end 2500's in it featured right here on YF.
    LM2500+G4 | Marine Engine | Gas Turbine Engines | Turboshaft | GE Aviation
    Note the FO Cons in that article - that is for a very narrow band of operation, like any GT any deviation and you will need some more columns for the numbers
  10. weto
    weto Senior Member
    NOR CAL
    That's EXACTLY why I presented it as a question. ????
  11. Marmot
    ???? Sure didn't read like a question, it looked just like a GE Land and Marine engine offered up as a "version" of the advertised engine. Just because the GE engine has a 1600 in the model number doesn't mean it is made by "they" which in the context of this thread means Turbomeca, the French company that built the Turmo engine the rest of us including the OP are talking about.
    They (Turbomeca) build low power turbines for light aircraft and helicopters, "they" don't "also have a marine version" called a GE LM1600. General Electric does though. Those engine can be used in boats but it's more a gimmick than a practical powerplant.
  12. weto
    weto Senior Member
    NOR CAL
    Actually it was a question but what ever makes you feel better....
  13. David Pearce
    David Pearce New Member
    New Zealand
    Hi do you still have these for sale.
