Click for NorthCoast
Click for Heesen
Click for Horizon
Click for Moonen
Click for Oceanco
Go Back   YachtForums.Com > YACHT & BOAT FORUMS > Motor Yachts > Burger Yacht > A fist full of new observations
Reply
Old 11-09-2007, 03:16 AM   #1
burgersboat
Registered User
Boy have I heard some new things about Burgers.
#1. Heard today that Burgers has a contract for a new boat, Size ?? but it has a new twist.
It's going to be built for someone from Europe that doesn't trust an Aluminum hull, so they want it built out of steel. My source doesn't know if it's going to be built along the same thoughts Feadship used to be built on , Steel hull w/an aluminum house. But he knew of the method. Peterson Builders (in Sturgeon Bay) built boats that had Steel Hulls w/aluminum Topsides.
I have a piece of the metal that is used to join those 2 different metals, 1/2 steel & 1/2 aluminum. It's an interesting piece.
Burgers is going to have their hands full if this is the case. There's no-one down there that has ever worked with steel.
I hope it's (the boat)is not too heavy for the 500 tn. "Marine Travel Lift"
#2. I saw Don O'Kief at the bank yesterday. He said he is semi-retired, but is building small aluminum boats on the side. He said he's got 1 boat built and 3 in the works. They're 33' long with an 8' beam. He wants them to be able to transport them down the road. so he has to keep the beam @ around 8' wide..
#3. Burgers laid off 40 workers a couple of weeks ago, I believe that's because of stopping the work on hull # 503. I believe that's the hull #.
burgersboat is offline   Reply With Quote
Old 11-09-2007, 12:04 PM   #2
Loren Schweizer
YF Associate Writer
That "piece of metal" is likely 'Detaclad', developed by DuPont, and something that the U.S. Navy has been using for decades... not to mention the boatbuilders down in Alabama such as Real Ships which have produced steel/aluminum expedition-style vessels for over ten years.
It ain't rocket science. Plus, welding steel is a lot easier than tacking aluminum plates together IMHO.
Loren Schweizer is offline   Reply With Quote
Old 11-09-2007, 04:08 PM   #3
burgersboat
Registered User
Maybe so, but it's the weight of steel vs. Aluminum that I find interesting.
When you get over 110 feet, those bottom plates start getting thicker & heavier.
The last steel hull that left Burgers was , I think the Titian a 96 footer built in the late 50's or early 60's.
Old 01-10-2008, 08:24 PM   #4
Topher
Registered User
You are correct. It is Detacoupling.
Topher is offline   Reply With Quote
Old 01-11-2008, 12:53 PM   #5
K1W1
Senior Member
K1W1's Avatar
Here is a link to a manufacturer that explains about Deta Couple or Triclad as it is also known.
http://www.dynamicmaterials.com/data...ct%20Sheet.PDF
__________________
Cheers,
K1W1
K1W1 is online now   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
All times are EST. The time now is 06:42 PM.
Click for Queenship
Click for Shadow
Click for Rybovich
Click for Queenship
Click for Lazzara
Click for Trinity
