| |  | Broward sudden stern swing? |  | | |
09-25-2009, 10:59 AM
#1 | | Registered User
This Broward, like so many of the same vintage had a cockpit extension at some stage in its career changing it from the original 94-106.
I recently had an experience entering Ixtapa inlet in dead-calm weather where the stern went almost out of control, threatening to put us across the inlet, and that at about 1000RPM.
My concern now is whether we are in for some nasty surprises in a real following sea.
The props are 12-15'ahead of the stern and the extension was of a much lighter grade aluminium which seems to create buoyancy.Another concern is that a swim-platform is planned at the next haulout and could perhaps further exacerbate the condition, acting like a big fat trim-tab.
Has anyone had a similar experience or have any thoughts on this issue?
I was wondering about the addition of skegs.
09-25-2009, 11:09 AM
#2 | | Senior Member
| Quote: | Originally Posted by libertyac I recently had an experience entering Ixtapa inlet in dead-calm weather where the stern went almost out of control, threatening to put us across the inlet, and that at about 1000RPM. My concern now is whether we are in for some nasty surprises in a real following sea. |
What happened to make it go "almost out of control" in dead calm conditions? Were there any UFOs or strange fog banks nearby? Was the bow still in control when this happened?
09-25-2009, 12:33 PM
#3 | | Senior Member
| Quote: | Originally Posted by Marmot What happened to make it go "almost out of control" in dead calm conditions? Were there any UFOs or strange fog banks nearby? Was the bow still in control when this happened?
Were you airlifted onboard just moments before the vessel "went almost" out of control? Surely if you are the master you have maneuvered the thing in various sea conditions other than "dead calm" and have some inkling of how it performs. You should be the one person who can answer your questions. |
Is it possible for you to share your obvious wealth of knowledge without the incessant derision of others?
09-25-2009, 02:39 PM
#4 | | Registered User
| stern warning
First of all there's the assumption that I was running the boat, whereas I was the engineer, secondly the boat is new to us and we have not had experience of as many sea conditions as we would like.
The downward leg to Panama was all from the Port side and the Upward leg, to the Baja flat as a lake.We've also had some good seas on the bow but nothing to speak of astern.
All I can think was that there was a side current at the entrance and that the helmsman was not giving the boat enough 'way'
I also think he reacted with the wheel instead of the throttles but it did give cause for concern.
An experienced Naval architecht/surveyor also picked up on it when he was studying the haulout pics and that was before I told him of the éxperience
09-25-2009, 02:53 PM
#5 | | Senior Member
| Quote: | Originally Posted by libertyac First of all there's the assumption that I was running the boat, whereas I was the engineer ... |
In that case, why not just ask the guy who was driving? If the boat was "almost out of control" in dead calm conditions surely the bridge team would be a good place to start asking questions.
09-25-2009, 05:43 PM
#6 | | Registered User
| stern warning
The obvious reaction was"What the #$@^%"to which the reply was "*6$#@ if I know" so thats been covered.
I thought my post was really rather simple: Has anyone experienced anything similar with an extended Broward?
If not Silence would suffice for "No"
If so, some positive feedback would be good.
09-25-2009, 06:23 PM
#7 | | Senior Member
| Quote: | Originally Posted by libertyac The obvious reaction was"What the #$@^%"to which the reply was "*6$#@ if I know" so thats been covered.
Thanks |
Very little information was "covered" in your post. Now that you have provided some information, it appears that the seller or his crew said nothing about unusual handling characteristics, none were observed during the sea trial, (if one was performed pre-purchase) and you guys drove it a fair ways across the hemisphere with no problems until entering a channel. At that point the boat went "almost out of control" in "dead calm" conditions for no descernible reason.
At the risk of being accused of being contentious or (heaven forbid) even derisory, has your resident Son of Magellan considered doing a handling trial to find out if his new charge has suddenly developed dangerous characteristics or to see if that little quirk can be duplicated with a following sea? Did anyone notice if the steering system might have contributed to this peculiar behavior? Or if maybe some bright spark pushed a button or twisted a knob to see what it would do? Was it on autopilot, followup or non-followup steering? Lots of possibilities here besides a sudden and rather late onset of poor design.
09-25-2009, 06:53 PM
#8 | | Registered User
Thanks |
The simple answer is "Yes", in following, especially quartering sea conditions, they get pushed around quite a bit, and I have been nearly broached in them in relatively small conditions, 6'-8' when making the turn into Marina Del Rey. As you have surmised, it takes a healthy handful of throttle along with the rudder to bail you out due to the small rudders and lack of leverage.
09-25-2009, 09:39 PM
#9 | | Senior Member
Back in the early 90's there were quite a few boats extended and , although this is 2nd hand, I remember several people telling me that their handling characteristics were ruined as well as other problems such as bad welds and supporting structure. I don't think it takes a genius to figure out that adding 10' to a 100 footer, in effect moving the running gear 10% forward is going to affect handling. From personal experience I can say that the weight of a hydraulic swim platform changes the handling and speed on a 51' Bertram or a 46' Sea Ray for the worse.
__________________ "Some went down to the sea in ships." |
09-25-2009, 11:45 PM
#10 | | Senior Member
I've run quite a few Motoryachts with extensions, including a 103' Broward that had not 1, but 3 stern extensions.
The trick is, you have to keep the stern heavy always. They almost always add another fuel tank in the extension and a water tank also, this is to balance out the extra bouyancy the extension created and trying to keep from moving the center of gravity foward. If the stern is light, the bow will dig in and the stern will swing 90 degrees or more in a following sea. It doesn't help to have your running gear 10' foward of where it should be either. Drain the fuel from the bow first and the stern tank last, this will help immensly by keeping more weight on the stern. even still they don't handle as well as without the extension, but this makes it livable.
09-25-2009, 11:50 PM
#11 | | Senior Member
| Quote: | Originally Posted by Marmot Very little information was "covered" in your post. Now that you have provided some information, it appears that the seller or his crew said nothing about unusual handling characteristics, none were observed during the sea trial, (if one was performed pre-purchase) and you guys drove it a fair ways across the hemisphere with no problems until entering a channel. At that point the boat went "almost out of control" in "dead calm" conditions for no descernible reason.
At the risk of being accused of being contentious or (heaven forbid) even derisory, has your resident Son of Magellan considered doing a handling trial to find out if his new charge has suddenly developed dangerous characteristics or to see if that little quirk can be duplicated with a following sea? Did anyone notice if the steering system might have contributed to this peculiar behavior? Or if maybe some bright spark pushed a button or twisted a knob to see what it would do? Was it on autopilot, followup or non-followup steering? Lots of possibilities here besides a sudden and rather late onset of poor design. |
If you had any real world experience running a motoryacht with an extension, you'd know that it is the nature of the beast in a following sea or following current and has to do of where the rudders are located and the vessel's pivot point being too far foward, nothing to do with who was at the helm. Although having someone experienced at the helm helps maintain control.
The simple problem is having the weight in the wrong place with a yacht with an extension causing the bow to dig in and the stern to surf in whichever direction it wants.
A swim platform would help add a little more weight back there and probably help the situation (as long as it's out of the water) and as long as it has adequate drainage (slats or such) it shouldn't act like a trim tab.
09-26-2009, 08:40 AM
#12 | | Senior Member
| Quote: | Originally Posted by Capt J If you had any real world experience running a motoryacht with an extension, you'd know that it is the nature of the beast in a following sea or following current. |
Having driven tugs, yachts, and my own boats up and down the inside passage between Seattle and SE Alaska I do know how following seas and the strongest currents in the world can effect a boat, extended or otherwise.
Having read the original post, which seems to be ignored by most contributors to this thread, the conditions in which this boat "went almost out of control" were stated to be "dead calm." That says there was no following sea, no strong current. The boat was proceeding along normally as, evidently, it had for the previous few thousand miles without incident.
There is more to this story than the poster has contributed. Either the conditions were not "dead calm" or something else happened. Maybe if he gave the name of the boat a reader with experience driving that boat could ask the right questions. If this boat has a tendency to go "almost out of control" in "dead calm" sea conditions surely someone else has had the pleasure of that experience and would share the story. In the meantime, color me skeptical.
09-26-2009, 09:18 AM
#13 | | Registered User
| Quote: | Originally Posted by Marmot Having driven tugs, yachts, and my own boats up and down the inside passage between Seattle and SE Alaska I do know how following seas and the strongest currents in the world can effect a boat, extended or otherwise.
There is more to this story than the poster has contributed. Either the conditions were not "dead calm" or something else happened. Maybe if he gave the name of the boat a reader with experience driving that boat could ask the right questions. If this boat has a tendency to go "almost out of control" in "dead calm" sea conditions surely someone else has had the pleasure of that experience and would share the story. In the meantime, color me skeptical. |
I normally only connect "dead calm" to wind and sea state and not to current, that would be "still water". What all actually happened there is up for bid, but good tidal rips are known for the area.
09-26-2009, 09:21 AM
#14 | | Registered User
| Stern warning
Thanks to all those who took the time to respond courteously and patiently to my post. I lack the experience of some of our more senior members and believe in examining all the possibilities when something like this occurs.
Prevention is better than cure etc and since the boat will be out of the water soon, this would be a good time to see if any remedial action can be taken
Incidentally, someone who has been in and out of Ixtapa told me that he had a similar experience with a nasty cross-current there also, and nearly became a tourist attraction.
Once more thanks
09-26-2009, 10:02 AM
#15 | | Senior Member
| Quote: |
Incidentally, someone who has been in and out of Ixtapa told me that he had a similar experience with a nasty cross-current there also ...
So, there is more to the story. You never said there was a "nasty cross-current" and the Sons of Magellan, according to you, only said "*6$#@ if I know" which indicates that if there was a current, they were unaware of it. Which brings us to the next statement. Quote: | Originally Posted by libertyac Prevention is better than cure etc and since the boat will be out of the water soon, this would be a good time to see if any remedial action can be taken |
Yes indeed prevention is better than cure. Planning the arrival means knowing the speed and direction of the current. So, if there was a strong current that the SoM did not know about, wouldn't yoou agree that proper planning might have prevented a potentially dangerous situation? That is the prevention side of the equation.
Now you say you are going to see what "remedial action" might be taken when the boat is out of water. Does this mean you are going to shorten the boat aft or lengthen the shafts and relocate the rudders? Why look for a technical solution to an operational failing? If there was a strong current across the inlet then you already know where the problem was located, it was in the wheelhouse.
Do you want to know why I sound so "impolite" about this? Because here is another poster-boat for why owners get out of yachting. Poor planning and perhaps even incompetence is cloaked with the possibility of poor design or some other item that might be fixed with enough of the owner's money.
If there was no current and conditions were indeed calm then as engineer maybe you need to find out if there is a problem with the steering system or the bridge crew's knowledge of how to operate it. Like I keep saying, there is more to this than has been posted.
Posting Rules
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are EST. The time now is 09:06 PM. | |
