Blohm+Voss Eco 73m 39kn
Information from Blohm+Voss
http://212.72.173.53/en/page.php?page_id=PG-134
Delivered in 1991, the yacht is characterized by a very high level of comfort and an extremely high speed. The yacht is suitable for Atlantic crossings. The propulsion plant consists of two KHD diesel engines and a gas turbine each driving a water jet unit.
The revolutionary design was conceived by Martin Francis, France, whereas the interior was designed by Francois Zuretti.
An economic cruising speed is ensured by the two diesel engines, while a maximum speed of more than 37 knots can be reached with the gas turbine. Such an extreme speed is only possible when consequently following light-weight construction. High-strength, 4 mm thick steel was used for the hull, whereas the superstructure was made of GRP. The automated propulsion plant can be controlled via conventional control levers or flying joystick units so that the yacht can be operated from different locations.
Another specific feature is the robot-like, automatic crane for the seaplane arranged in the stem area and the two special tender boats.
Characteristics:
Length overall: 74.1 m
Breadth: 11.2 m
Draught: 3.5 m
Speed: 37 kn
14 passengers (including the owner)
19 crew
Picture was taken from:
http://www.francisdesign.com/yachts/motor/eco.htm
