Click for Burger Click for Cross Click for Westport Click for Ocean Alexander Click for YF Listing Service
Bertram 33' 1989
Discussion in 'Bertram Yacht' started by Gazmonte, Jun 11, 2008.
  1. Gazmonte
    Gazmonte New Member
    North Miami, Florida
    I'm about to close on a 33' 1989 with carburated 7.4lt, any idea of fuel burning?
    although I'm planing in using it as a trawler most of the time.
    are these engines big enough for a heavy boat? any issues I should look for?
    Thank you for your advise
  2. CaptPKilbride
    CaptPKilbride Senior Member
    On the water
    If you want a trawler, get a trawler.
    The 33 has a very low sheerline, and with the deep V hull there is not much bouyancy or volume in the bow. It will not track well, and be unstable with a snap-roll at displacement speeds. Once on plane, it is a great boat, with great handling... but it was never designed or meant to be operated comfortably as a trawler. Just my $0.02
  3. Gazmonte
    Gazmonte New Member
    Hi capt, you are right, what I meant was that I would go slow most the time (which I do anyways), just wondering the fuel burn at different RPM
    Thank you
