Click for Westport Click for Burger Click for Cross Click for Nordhavn Click for Walker
Bertram 28 Fiberglass Fuel Tank
Discussion in 'Bertram Yacht' started by rdalessio, Apr 24, 2006.
  1. rdalessio
    rdalessio New Member
    Bristol, RI
    Hi: My 1983 Bertram 28 has a fiberglass fuel tank and, with the change-over to ethanol gas, it is going to have to be replaced. Does anyone know where I can get the dimensions for this tank so that I can get a new one fabricated? It holds approximately 190 gallons. Thanks for your help.
    Regards, Dick
  2. CTdave
    CTdave Senior Member
    Greenwich CT/ Stuart FL
    I would call Bertram directly. Have your hull ID. With that, they can tell you everything about your boat.
    I have read a few discussions about the ethinol/fiberglass tank problem & I hear talk of some sort of "coating" being sprayed into tanks to protect them.
    Good luck!
  3. PHILRAJOTTE
    PHILRAJOTTE New Member
    FARMINGDALE,LONG ISLAND,NEW YORK
    The Size Of Your Tank Should Be 79 Inches Long By 33 Inches Wide By 20inches Deep And Have Two Angles Oneach Side Running Down The Center Of The Boat I'm Building Two Of Those Tanks Right Now If You Need A Drawing Give A Call 1-888-594-9353
  4. Bert28
    Bert28 New Member
    Naples, FL
    I'm just finishing up on a total restore of my 73 Bertram 28. Since I had her totally stripped down, I replaced the tank with a custom aluminum that I designed from bulkhead and clearance dimentions. It holds 195 gallons and was welded by a friend of mine in his fabrication shop costing me $900. I then coated the tank in Awlgrip. I called Hightide Marine and they would only warranty their fiberglass tank for 5 years. I thought of making my own fiberglass tank, but all the resin suppliers told me the same thing, even the corrosive tank makers that they would only warranty for no more than 5 years. Hope I made the right decision, time will tell.
