Click for Ocean Alexander Click for Cross Privacy Matters Click for Northern Lights Click for Nordhavn
My Bertram 28 rehabilitation thread.
Discussion in 'Bertram Yacht' started by atomlab, Nov 14, 2010.
  1. atomlab
    atomlab New Member
    Europe
    Hi there.
    This week so did i bought a Bertram 28" flybridge from -79.
    Well as you see so do i need to replace almost everything. First so do i need to take everything apart.
  2. RER
    RER Senior Member
    Newport Beach CA
    Wow... how did the venturi survive?
  3. ScrumpyVixen
    ScrumpyVixen Member
    Sydney
    Look like it needs a little bit more than a clean and polish.
    Withthe amount of work needed, I can only assume you are single or soon to be single.
    Scrumpy
  4. K1W1
    That looks like it will certainly be a fulltime job for the foreseeable future.
    Are you going to stick with the Gas engines or re-power with Diesel?
  5. Ormond Bert54
    Ormond Bert54 Senior Member
    Ormond Beach, FL
    Looks like it's going to be a VERY EXPENSIVE Bertram 28. The tough lesson of the economics of a "fixer upper" is going to be learned on this one. Very rewarding and very expensive. Have fun with it. I love my Bertram 28.
  6. dsharp
    dsharp Senior Member
    lake jackson, tx
    One of Bertram's "better" ideas- put the hatch edge over the top of the carb. where water can drip all over it. I wouldn't take it apart. Give it a good scrubbing and remove the junk. I would check the wheels and thru hulls, do a bottom job and get it in the water where it's not so hard to get on and off. I don't care how well you plan you will forget something and end up making 50 trips up and down a ladder.
