Click for Walker Click for Perko Click for Mulder Click for Burger Click for Cross
Fresh Water Tank 1984 38
Discussion in 'Bertram Yacht' started by Mullide, Oct 10, 2010.
  1. Mullide
    Mullide New Member
    Cincinnati, OH
    I found a small leak in on the bottom of my fresh water tank, which was an aluminum cube. I had to cut the salon floor, move the water heater and remove the tank to get a good look. The leak was on the bottom of the tank. Once removed, it was clear the tank was experiencing some widespread corrosion. With little to lose, we cut the tank open and found it was pitted everywhere and about to fail in a big way. I am now cleaning and painting the bilge, since everything is accessible due to the floor being cut away. I am looking for a replacement tank of about the same size (100 gal) but in plastic. It appears the life expectancy of the aluminum tank is 26 years in my case.
    It might be easier and cheaper to make a new tank in place out of fiberglass if you have the access to do it. If not, when we need aluminum tanks made, we usually go to a local welding place that makes them to your specs.
  3. Marmot
    It is nearly certain that you can find an off the shelf poly tank that will replace the old tank perfectly at a very reasonable cost.
    Spend a couple of minutes with Google.
  4. Mullide
    Mullide New Member
    Cincinnati, OH
    Thanks for both comments. I am looking on line for a plastic replacement. I should be done with that project soon.
  5. NYCAP123
    I don't have a Boats & Harbors handy, but there's an ad running in it by a company that makes them in almost any size or shape you need. You can find it on line.
