Click for Burger Click for Northern Lights Click for Westport Click for Nordhavn Click for Cross
1975 35' Bertram - Holding Tank/Windscreen
Discussion in 'Bertram Yacht' started by WoJohnsonJr, Feb 5, 2010.
  1. WoJohnsonJr
    WoJohnsonJr New Member
    Tybee Island Ga
    Hey Yall,
    Im looking for any tips on the best size, material, and location for the installation of a new holding tank in my 35 Bertram. Also am trying to locate a rubber gasket/seal that goes between the base of the windscreen and the flybridge. All input will be appreciated, will also try to get some photos up of the project for you guys too!
    Thanks!
  2. Pascal
    holding tank... biggest you can fit! well, almost but you get the picture. it also depends on the kind of head you have, with Vacuflush you can get away with a smaller tank. Ideally you want the tank as close to the head as possible to minimize hose run. 30 to 40 gallons would be ideal on a boat that size.. i also depends on how much you use the boat and how easy it is to find a working pump out station in your area.
    go for heavy duty plastic tanks, you can find them from most online suppliers
