Click for Oceanco
Click for Delta
Click for Lurssen
Click for Christensen
Click for Moonen
Click for Nordhavn
Go Back   YachtForums.Com > YACHT & BOAT FORUMS > SportFish Yachts > Bertram Yacht > Bertram 28; another mystery
Reply
Old 01-26-2010, 06:51 PM   #1 (permalink)
Registered User
This is another thing on my boat that I dont know what it is or its function. This is on the bathroom. The toilet has a macerator but dont have a holding tank. The only tank is the one on the picture. Also it has a swith on the bathroom wall, I dont know its use. Another question I have is, If this boat originally comes with a holding tank and where it is located.
ipeoples is offline   Reply With Quote
Old 01-26-2010, 07:24 PM   #2 (permalink)
Senior Member
Bayside Bert28's Avatar
The holding tank (if there is one) would fit aft of the potty against the port side hull next to the port side engine and just aft of the single battery. Mine is located there and holds approx 25 gallons. It also has a Y valve located just forward of the holding tank that directs the flow into the holding tank or overboard. I have a different potty that doesn't include that little tank.
Bayside Bert28 is offline   Reply With Quote
Old 01-26-2010, 07:33 PM   #3 (permalink)
Senior Member
NYCAP123's Avatar
Just a guess, but that looks like a holding tank of sorts. I think I see a valve before it to direct waste to the tank or overboard. Since it's higher than the head I suspect that switch is a pump. Looks like a DYS project so just follow the lines for the sure answer.
NYCAP123 is online now   Reply With Quote
Old 01-26-2010, 07:51 PM   #4 (permalink)
Senior Member
Marmot's Avatar
Quote:
It is a 2-gallon Lectrasan salt tank. When that type of treatment unit is used in fresh water it requires a source of salt to make the wastewater electrically conductive.
Marmot is offline   Reply With Quote
Old 01-26-2010, 08:46 PM   #5 (permalink)
Senior Member
NYCAP123's Avatar
Quote:
Love days when I learn new things. Thanks Marmot.
Old 01-28-2010, 07:43 PM   #6 (permalink)
Registered User
Thanks all of you guys, I learn something new too with Marmot.
Old 01-28-2010, 08:37 PM   #7 (permalink)
Senior Member
chesapeake46's Avatar
Manufactured by Raitan Engineering, Millville NJ and in Ft Lauderdale, Fl.
I have had very good customer service with this manufacturer.
Google them for more info.
chesapeake46 is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
All times are EST. The time now is 07:28 PM.
Click for Cheoy Lee
Click for Westport
Click for Dockwise
Click for Cheoy Lee
Click for Cape Scott
Click for McKinna
