Click for Westport Click for Burger Click for YF Listing Service Click for Glendinning Click for Ocean Alexander
63e Bertram Burning Wheels
Discussion in 'Bertram Yacht' started by BD0078, Nov 26, 2009.
  1. BD0078
    BD0078 New Member
    JACKSONVILLE
    second set of wheels with less than 50hrs are still cavitation burning
  2. Kevin
    Welcome to YF BD0078
    You might want to give our members some more details about your problem.
  3. Henning
    Henning Senior Member
    Ft Lauderdale FL
    Need to know Pitch, Diameter, Blade count, brand & style, material, clearance from the hull and how far up the shaft is the zinc if so fitted. The last is an issue I have addressed on several boats with cavitation issues, the shaft zinc being too close to the prop.
    I have seen a lot of issues with Michigan/Federal wheels on 30+ knot SF's. Some companies have switched to Veems and the problem with prop burn stopped. It seems to be mostly a clearance issue with the props being too close to the hull, from what I have seen. More info would be nice. I did see a set on a new boat with a 100 hours with A LOT of prop burn to what looked like it was a structural issue with the propellor at that point.
