Click for Ocean Alexander Click for Ocean Alexander Click for Glendinning Click for JetForums Privacy Matters
Replacing Bertram 28 fuel tank
Discussion in 'Bertram Yacht' started by Sunshine326, Nov 16, 2009.
  1. Sunshine326
    Sunshine326 Guest
    I have a 1973 Bertram 28 Sport Fisherman. She has a 165 gallon tank that we are needing to replace. First the issue is getting the correct dimensions. But also we thought about possibly removing the top of the tank and having a new tank built to place inside and use the old tank as a cradle. Looking to get opinions on this idea. Is it even legal? Does anyone know how to get the correct dimensions? Any ideas and/or opinions are greatly appreciated.
  2. m2m
    m2m Senior Member
    newport ri
    I have done exactly what you are describing on several boats, works like a charm and sometimes keeps the structual integrity of the boat intact. The only drawback is the loss of some of your capacity
  3. Sunshine326
    Sunshine326 Guest
    Thank you for the info... do you have anyone you would recommend to manufacture the tank and also maybe someone who would install? I found someone in Williston to do the tank and then another guy in Crystal River that may be able to install it. It's always nice to get a couple of estimates though.
  4. m2m
    m2m Senior Member
    newport ri
    i would stay away from aluminum or stainless steel In my experience a poly tank is the way to go. Moellor has a website for these tanks which are roto-molded. (I do not work for Moellor)
  5. Dhowdodger
    Dhowdodger New Member
    Arabian Gulf
    Turtle pac flexi tanks are the way to go, I dont work for them but have used them.
