Click for Ocean Alexander Click for Glendinning Click for Westport Click for Westport Click for YF Listing Service
Bertram Fuel Tanks
Discussion in 'Bertram Yacht' started by keithFWB, Nov 13, 2009.
  1. keithFWB
    keithFWB New Member
    Destin
    I have removed the old fiberglass fuel tank from my 1968 Bertram Moppie. Doeas anyone know a source for replacement tanks or where I can find the exact speca for the tank I removed?
  3. bertram28
    bertram28 New Member
    Bahamas
    Give Danny Piedra a call at High Tide Marine in Marathon,Florida..................he has a line on new O.E.M. Bertram fuel tanks................google for High Tide Marine.....................
  4. Ormond Bert54
    Ormond Bert54 Senior Member
    Ormond Beach, FL
    I would go to Bertram31.com and post your question.
    My Bertram 28 has a single aluminum 200 gallon tank that is beautifully made ... previous owner installed it ... The name is slipping my mind ... see what kind of responses you get from Bertram31.com ... if you need I can have one of my contacts local to my boat go to the boat and look up the information.
    Mike
    301-509-1211
    Glasstek in Miami is located minutes away from the Bertram factory and does a lot of reproduction older bertram fiberglass, like the entire cockpit fiberglass sections and stuff. They probably also know the exact dimensions of the fuel tank that came out and may have new ones in stock.
  6. 35bert
    35bert New Member
    daina
    is there a hole?
    is it a gas boat? did you find rot? I pulled a tank out of a 1973 35 bertram a gas boat, being repower to diesel. I cut 6 holes 12" x 12" between the internal dividers. I cut the holes to check for damage from the ethanol, I heard reports of it eating holes in older fiberglass tanks... In my case there was no damage what so ever on the inside of the tank. I had planed on coating the inside with vinylester but after seeing how nice the inside was and not hearing any thing bad happening to tanks in diesel bertrams, I left it alone patched my inspection holes and reinstalled the factory tank....
