Click for Delta Click for Ocean Alexander Click for Glendinning Click for Nordhavn Click for Westport
Rust on an aluminum hull Roamer?
Discussion in 'Chris Craft Roamer Yacht' started by Triton, Feb 10, 2013.
  1. Triton
    Triton New Member
    Galveston, Texas
    I am a new owner and I just had my vessel waxed (73 aluminum 60') and I have a couple of places that look like rust is coming through the paint. One is on the deck in front of the windlass (see attached JPG file named "Rust_Pic.jpg) and the other is the upper deck salon roof area. How is this possible?:confused:
  2. alloyed2sea
    alloyed2sea Moderator
    Alex, VA
    Sherlock Holmes
    Watson -
    What facts do we know about the oxymoronic case of "The Mysteriously Rusting Aluminum"?:
    1. Aluminum simply doesnt "rust" - its surface layer oxides and quickly forms a self-protecting patina (pink) whereas steel/iron forms an oxide which flakes off exposing more metal to attack (red).
    2. Now, we know corrosion often results from salts and contaminants which may have leached into the aluminum (oxide) surface - possibly during paint prep.
    3. Similarly, iron, copper or steel contaminants (steel wool filings or somebody's idea of non-skid perhaps?) may have gotten into the paint only to be exposed later (much to boat owner's chagrin).
    4. Finally, and most unlikely - red mercury is at work:
    The Amazing Rusting Aluminum | Popular Science *WARNING: Keep this a secret.**
    BOTTOMLINE: Try re-coating those areas (thick enuff to prevent contact with oxygen) and see if that solves the problem.
    It looks like steel fragments have gotten on, into the paint. Do you have galvanized anchor chain and was the windless used recently? Has it been around a boatyard where they've been grinding on steel? It could've fallen into the fairing material prior to painting, but it looks like it's from fallout. Carefully put a little whink on it and see if it dissolves it.....
  4. Pascal
    This looks like classic case of steel shavings from cutting or drilling into stainless steel and not cleaning it up thoroughly. The dust will rust very quickly and stain the surface
    Spraying rust stain remover will take care of it
  5. Ormond Bert54
    Ormond Bert54 Senior Member
    Ormond Beach, FL
    Thanks Pascal ... Nice to hear an easy solution once in a while!
  6. Old Phart
    Old Phart Senior Member
    I dunno
    Does it contain Hydrofluoric acid?
    Hydrofluoric acid - Wikipedia, the free encyclopedia
  7. Pascal
    Galvanized chain may rust and leave a stain but the little grains are signs of either cutting, grinding or drilling
  9. alloyed2sea
    Alex, VA
    (Bad) Genie
    Just a bit (Hydrogen Fluoride -1.50 – 3.5%), and some Denatonium Benzoate (0.01 – 0.10%), SO?
    http://www.wardrobesupplies.com/ass...ts/Whink Rust Remover 10062008.pdf?1323898750
    "Very toxic by inhalation, in contact with skin and if swallowed. Causes severe burns. Inhalation of vapors in high concentration may cause shortness of breath (lung edema). Ingestion causes burns of the upper digestive and respiratory tracts. Will penetrate skin and attack underlying tissues and bone." :eek:
    Oh dear.
    Careful!
    -E
  10. doug p
    doug p Member
    PNW
    Looks like steel wool to me.
