Click for Delta Click for Westport Click for YF Listing Service Click for Westport Click for Nordhavn
Aluminum hull bilge paint
Discussion in 'Chris Craft Roamer Yacht' started by gerconst, Oct 22, 2009.
  1. gerconst
    gerconst Member
    Elk Rapids Harbor, Michigan and Gibraltar, Michiga
    Does anyone know what silver paint chris craft used in the 41' aluminum hull? Dave
  2. homer1958
    homer1958 Member
    Annapolis MD
    Don't use it.. old stuff.. go with new technology... Awlgrip or Alexseal
  3. Henning
    Henning Senior Member
    Ft Lauderdale FL
    Well, it should be 5083 Aluminum, so why paint it at all? If you have bare metal, just leave it, or Alodine it. If you already have paint and are trying to make it pretty again, there are a couple of ways to go. There is something like Alumigrip which will use an etching primer and a linear polyurethane type top coat. Or you can go with a urethane rubber type product, or an epoxy paint.
  4. gerconst
    gerconst Member
    After further reasearch I think Chris Craft used it for a sound deadining. My 41' aluminum has a rough hard surface in the bildge. I looked at one 15 years ago and it had a soft surface that you could scrape of to get to the hull.
