Click for Nordhavn Click for Abeking Click for Walker Click for Westport Click for YF Listing Service
| Alloy | 58M | "Kokomo" | 2010/18 |
Discussion in 'Alloy Yacht' started by Yacht News, Dec 20, 2007.
    There is nothing like doing it thrice! This can be said of the owner of the new Kokomo. Not to be outdone, this will be his third luxury sailer under the same name built by the same ship yard. It seems he is building a bit bigger each time.
    Kokomo III is to be a whopping 58M long, that is nearly 200 feet. When launched she will surely eclipse the s/y Tiara for being the largest launch from the Alloy yard. To accommodate the impending launch of the Kokomo III in December 2009, the yard will have to extend two building bays and dredge a deeper pit for her.
    Designed by Dubois Naval Architects and having an interior by Redman Whiteley Dixon, her design can be said to be in safe hands. The dimensions of this yacht will be significant. A 234.3 foot carbon fiber mast, an overall hull length of 191 feet, beam of 36 feet and a maximum draft of a whopping 26.5 feet make up the main dimensions.
    Inside, the accommodations will be separated into an owner's stateroom, four individual guest rooms all with ensuite facilities and crew accommodations. The crew accommodations will be separated into the Captain's room, Engineer's room and four other rooms for the other crew. All will feature ensuite facilities, the advantage of a large yacht!
    Power will be provided by way of 2 X CAT 872 HP diesel engines. Connected to them will be Hundested variable pitch propellers. Kokomo III will be constructed to meet the stipulations of the Lloyd’s X100 A1 SSC YACHT MONO G6 MCH classification.
    A summation of statistics are provided below:
    Designer Dubois Naval Architects
    Builder Alloy Yachts
    Interior Designer Redman, Whiteley, Dixon
    LOA: 58.4M
    LWL: 51.5M
    Beam: 10.9M
    Draft: 4.9M/8.05M
    Displacement: 450 Tonnes
    Construction: Aluminum
    Main Engine: 2 x CAT C18 872 HP
    Generator: 2 x CAT 105 KW
    For more on the Kokomo III, visit the Alloy website at:
    http://www.alloyyachts.co.nz/news.php
    http://www.mcmnewport.com/English/CONSTRUCTION+MANAGEMENT/KOKOMO+58.4.html
  3. brian eiland
    brian eiland Senior Member
    St Augustine, Fl and Thailand
    Just wondering...what business is this owner in that affords him the pleasure of continuing to build these big sailing craft??
  4. Yacht News
    Yea! the third and current one...is pretty large! nearly 200-feet
  5. Yacht News
    "Kokomo" on Monaco!
