Designer Comments:
Ed Dubois, Dubois Naval Architects: “The design brief for Ad Lib was based on the S.Q.N. philosophy of top end displacement speed, excellent sea keeping, first class layout and streamlined, elegant looks. Following the success of S.Q.N. (based on a tank tested hull) Ad Lib is a little faster with more waterline length and more powerful engines. The easily driven hull has excellent range/power ratio and her sea keeping is tried and tested. The layout is similar to SQN, but has been opened up in the saloon/dining area to give a greater feeling of space. The flybridge has been enhanced and the styling has the benefi t of the extra length."
Don Starkey of Donald Starkey Designs: “We are particularly pleased with Ad Lib’s appearance and we believe she will turn many heads. This was really a development from S.Q.N. but with darker woods and a slightly more ‘current’ modern style with more leather finishes. The expertise of all the craftsmen at Alloy Yachts and their knowledge of what real quality is made this one of the easiest projects to be involved in. The understanding from these craftsmen, who got into the spirit of our design, made the geographical distances between us disappear completely.”
SPECIFICATIONS:
YEAR BUILT: Delivery in November 2005
BUILDER: Alloy Yachts International
DESIGNER: Dubois Naval Architects
INTERIOR DESIGNER: Donald Starkey Designs
CONSTRUCTION: Welded aluminum hull & superstructure
CLASSIFICATION: Lloyds 100 A1 SSC Motor Yacht Mono G6 LMC MCA compliant
Length: 131ft (40m)
Beam: 27.89ft(8.50m)
Draft: 6.20ft (1.89m)
Displacement: 224 Tons Full Load
MAIN ENGINES: 2 x 1,450hp Caterpillar diesel engines type 3412E
GEAR BOXES: 2 x ZF type 1960 reduction gearboxes with 4:1 ratio
SHAFTS & PROPELLERS: 2 x Aluminum rudders with stocks keyed for tillers
2 x BT Marine bronze 1320mm diameter 5 bladed propellers
SPEED: Cruising speed about 13 knots
MAX SPEED: about 16.5 knots
RANGE: 2,530 n. miles at 13 knots / 4,550 n. miles approx. at 10 knots
AUXILIARY MACHINERY & ELECTRICAL SYSTEM
GENERATORS 2 x 55kw Northern Lights generators.
FUEL 36,334 liters (9,598 US gallons) in 5 tanks
Alloy Yachts
1 Selwood Road,
Henderson, Auckland, New Zealand
http://www.alloyyachts.co.nz
